The LED Ring on Homey Pro shows what it’s doing. Flows can also briefly display a custom animation.
Spectrum
Homey Pro is running normally, with the Spectrum screensaver enabled.
Rotating White
Homey Pro is starting up. This takes one to two minutes.
Rotating Pink
Homey Pro is installing an update. Keep the power connected.
Breathing Blue
Homey Pro is in Setup Mode, ready to connect over Bluetooth via the iOS or Android app. This appears before initial setup, or after holding the pinhole for 8 seconds.
Rotating Blue
Homey Pro is performing a task in Setup Mode, such as joining a Wi-Fi network or downloading a cloud backup.
Breathing Orange
Homey Pro is in Recovery Mode. This appears when the pinhole is pressed while the power cable is connected. Connect Homey Pro to a PC or Mac to update the firmware, or to create or restore a local backup.
Rotating Orange
Homey Pro is performing a task in Recovery Mode, such as installing an update, resetting to factory settings, or creating or restoring a local backup.
Breathing Red
Homey Pro has crashed and will restart automatically. If this happens repeatedly, restore the firmware with the Homey USB Tool.
Rotating Red
Homey Pro is resetting to factory settings. This happens after holding the pinhole for 30 seconds.
Off
Homey Pro is not powered on, or the screensaver is set to Off.
