The Homey app lets you customize your Home Screen with built-in and community-made widgets. Here’s how to add and move widgets.
Private and saved on-device
This private dashboard is accessible only to you and saved on your device.
1. Go to the Home tab
Open the Homey Mobile App and ensure you’re on the Home tab.
2. Tap your avatar
Tap your avatar in the upper-right corner, then tap Edit Home Screen.
Alternatively, you can scroll down on the Home tab and tap Customize.
3. Start adding a new widget
Tap to start adding a new widget.
4. Select a widget
First, select a widget by tapping one from the list.
Next, adjust the widget to your liking. For example, you can hide or modify the widget title. If you are happy with the settings, tap Add Widget.
5. Arrange your widgets
You can move widgets by long-pressing and dragging them. Additionally, you can tap the three dots (⋯) in the widget’s upper-right corner to access additional settings.
Tap if you want to add another widget. Otherwise, tap Done.
