The Homey app lets you customize your Homescreen with built-in and community-made widgets. Here, we walk you through the process.
Step 1
Open the Homey app and ensure you're on the Home tab.
Step 2
Tap your avatar in the upper-right corner, then tap Edit Homescreen
Alternatively, you can scroll down on the Home tab and tap Customize
Step 3
Tap to start adding a new widget.
Step 4
First, select a widget by tapping one from the list.
Next, adjust the widget to your liking. For example, you can hide or modify the widget title. If you are happy with the settings, tap + Add Widget
Step 5
You can move widgets by long-pressing and dragging them. Additionally, you can tap ⋯
in the widget's upper-right corner to access additional settings.
Tap if you want to add another widget. Otherwise, tap
Done
