You can manage all your existing Flows in the Homey app. Below, you will find how to disable or delete them.
Disabling a Flow
Step 1
Open the Homey app and tap Flow in the tab bar to access the Flow settings.
Step 2
Press and hold the Flow you want to turn off. Next, tap Disable.
Step 3
Once turned off, the Flow will grey out. To turn it back on, tap Enable.
Deleting a Flow
You can also delete Flows. However, a deleted Flow cannot be restored. Therefore, double-check your Flow before deleting it.
Step 1
Step 2
Press and hold the Flow you want to disable. Next, tap Delete.
