Homey can connect to a KNX installation using a KNX/IP Interface or KNX/IP Router.
Requirements
- Homey
- KNX/IP Interface (or KNX/IP Router). We recommend the KNX for Homey Kit, which comes with Weinzierl 731 KNX/IP Interface.
- The free KNX Homey App.
Installation of the KNX/IP Interface
Step 1
Place the KNX/IP Interface in an available slot on your KNX rail.
Step 2
Connect the KNX/IP Interface to your LAN network using the provided Ethernet cable.
Step 3
Connect the KNX/IP Interface to your KNX network using the provided KNX bus cable. Make sure the wire colors match.
Configuration of the KNX/IP Interface
1. KNX Address
Make sure that the KNX Address 15.15.255 is available. This is usually the case. If not, please ask your installer for help.
2. KNX/IP Interface
Ensure the KNX/IP Interface is connected to your LAN and has an IP address. If not, make sure DHCP is enabled on your internet router or assign an IP address manually.
Adding a KNX device to Homey
Step 1
Install the KNX Homey App on Homey.
Step 2
Open the Homey app on your phone and tap Devices in the tab bar.
Step 3
Tap → New Device in the upper-right corner.
Step 4
Search for KNX and tap its logo.
Step 5
Homey should automatically find the KNX/IP Interface. If not, you can enter the IP address manually.
Step 6
Select the correct KNX/IP Interface.
Step 7
Enter the KNX Group Address of the KNX device you want to add. For example, a light.
Step 8
Repeat this step for any additional KNX devices you want to add.
