Homey can control many devices from many brands at the same time, and the setup of new devices is straightforward. In case you need help, we're here to guide you through the process of adding a new device to Homey.
Pairing instructions
- Open the Homey app and select
Devices
in the tab bar below. - Tap the
symbol in the top right corner and chooseNew Device
. - Search the brand name of your device and select the corresponding app.
- When you've found the device you'd like to add, tap its icon → confirm if you want to continue → tap
Connect
. - Follow the on-screen instructions.
Every device requires a different method of adding it to Homey. Follow the on-screen instructions and you'll be set in no time!
