Homey works with the Slide motorized curtain rail manufactured by IIM. We've documented the pairing process, so take a look below.
Pairing instructions
Adding a Slide product to Homey works just like adding any other device.
- Open the Homey app and select
Devices
in the tab bar. - Tap the
symbol in the top right corner → search forSlide
→ tap itslogo
. - Look for the device you'd like to add → tap its icon → confirm if you want to continue → tap
Install
. - Follow the on-screen instructions.
Every device requires a different method of adding it to Homey. Follow the on-screen instructions and you'll be set in no time!
