Next to being stunningly beautiful, the LED Ring of Homey Pro (Early 2023) is also used to visualise what Homey Pro is doing.
Spectrum — Homey Pro is working normally, and the screensaver is set to Spectrum. | |
Rotating White — Homey Pro is starting. This should take between 1 and 2 minutes. | |
Rotating Pink — Homey Pro is installing an update. Do not disconnect the power. | |
Breathing Blue — Homey Pro is in Setup Mode. Use the iOS/Android app to connect using Bluetooth. This usually happens when Homey Pro is not yet set-up, or after holding the pinhole for 8 seconds. | |
Rotating Blue — Homey Pro is doing something while in Setup Mode. For example, connecting to a Wi-Fi network or downloading a cloud backup. | |
Breathing Orange — Homey Pro is in DFU Mode. This happens when the pinhole is pressed, while the power cable is connected. Connect Homey Pro to a PC or Mac to start a firmware update, or create/restore a local backup. |
Rotating Orange — Homey Pro is doing something while in DFU Mode. This can be either installing an update, resetting to factory settings, creating or restoring a local backup. |
Breathing Red — Homey Pro has crashed, it will restart automatically. If this keeps happening, try restoring the firmware using the USB Tool. |
Rotating Red — Homey Pro is being reset to factory settings. This usually happens after holding the pinhole for 30 seconds. |
Off — Homey Pro has either no power connected, or the screensaver is set to Off. |
Next to the animations listed, any Flow can also show an animation for a short period of time.
