You can connect Homey to Claude using the Homey MCP Server. Once connected, you can ask Claude to control devices, start Flows, set Moods, and more.
Manual MCP setup may require an eligible Claude plan
See claude.ai/settings/plans for your current plan.
Connect Homey to Claude
- Open Claude and go to Customize → Connectors.
- Click Add custom connector.
- Under Name, enter Homey.
- Under Remote MCP server URL, enter
https://mcp.athom.com.
- Click Add, then Connect.
- Sign in with your Homey account and approve access.
What you can do
Once connected, you can ask Claude to:
- Check device status and control devices
- Start, create, and update Flows and Advanced Flows
- Rename devices or move them to another zone
- Set Moods
Disconnect Homey from Claude
You can disconnect Homey at any time. After disconnecting, Claude can no longer access or control your Homey account.
- In Claude, go to Customize → Connectors.
- Find Homey, click the three-dot menu, then click Remove.
