You can turn off the LED ring of Homey Bridge on a schedule with a Flow, or permanently in the device settings.
Turn off on a schedule
Use a Flow to turn off the LED ring at a set time, such as 10 PM every night.
In the Homey app, go to the Flow tab.
Tap
in the upper-right corner, then tap New Flow.
Under When..., add the Date & Time card The time is ... and set the time.
- Under Then..., tap Add Card.
- Go to Home → the zone of your Homey Bridge → Homey Bridge.
- Set LED Ring to Off.
- Tap Next.
- Enter a name for the Flow, such as “LED ring off”.
- Tap Save Flow.
Turn the LED ring back on automatically
Create a second Flow with the same steps. Set the time to when the LED ring should turn back on, such as 7 AM, and set LED Ring to Spectrum.
Turn off permanently
- In the Homey app, go to the Devices tab.
- Tap Homey Bridge.
- Tap the settings icon in the upper-right corner.
- Tap LED Ring → Off.
To turn the LED ring back on, tap LED Ring → Spectrum.
