Set up Homey Pro with a new or existing Homey account. You plug in Homey Pro, then finish setup in the Homey app on your phone.
Before you start
Turn on Bluetooth on your phone and allow the Homey app to use it. On iOS, this permission is called Bluetooth. On Android, it’s called Nearby devices.
Connect Homey Pro to power
These steps connect Homey Pro to your home network over Wi-Fi. For a wired connection, follow the steps for the Homey Pro Ethernet Adapter instead.
- Connect the USB-C cable to the power adapter and to Homey Pro.
Plug the power adapter into a power outlet.
- Wait until the LED ring breathes blue. When Homey Pro starts up, the LED ring rotates white. After a minute or two, it breathes blue and Homey Pro is ready for setup.
If you’re new to Homey
- On your phone, download the Homey app from get.homey.app.
- Open the Homey app and tap Create Account.
- Follow the steps in the app to create your account.
Tap Set Up Homey → Homey Pro.
- Follow the steps in the app to finish setup.
If you already have a Homey account
- In the Homey app, go to the Home tab.
- Tap your avatar.
Tap My Homeys → Add New Homey → Homey Pro.
Troubleshooting
The LED ring doesn’t breathe blue
If the LED ring doesn’t breathe blue after two minutes, reset Homey Pro and try again.
