You can use the Homey Pro Ethernet Adapter with Homey Pro to add wired connectivity. Here, we explain how to set this up.
Plugging in
The Homey Pro Ethernet Adapter is designed to be placed near Homey Pro’s power adapter. This ensures all cables are together and out of sight, so Homey Pro will always be the eye-catcher in your home. Follow these steps, and you’ll be good to go.
1. Connect the power adapter
Plug the short end of the Homey Pro Ethernet Adapter’s cable into the power adapter.
2. Connect Homey Pro
Plug Homey Pro’s USB-C cable into the side of the Homey Pro Ethernet Adapter.
3. Connect the Ethernet cable
Plug an Ethernet cable into the Homey Pro Ethernet Adapter.
That’s it! Homey Pro will automatically use the Ethernet connection if it’s available. During setup, you’ll also have the option to connect to Wi-Fi.
Speeds
The Homey Pro Ethernet Adapter is a Gigabit adapter, but please note that the speeds are limited to USB 2.0 speeds (480 Mbit/s).
