The Homey Energy Dongle is designed for digital smart meters with a P1 port—a standard interface used for energy data in many European countries. It works with Homey Pro (Early 2023), Homey Pro mini, and Homey Cloud. Analog meters are not supported.
Regions with common P1 port support
P1 ports are typically found on smart meters in the following countries. While not every meter includes one, most modern models in these regions do.
Identifying the P1 port
The P1 port is typically labeled “P1” and uses a smaller RJ12 connector, making it easy to identify. If your meter mentions “DSMR” or “ESMR,” it is supported, though this label isn’t always visible.
Verified smart meters
The table below lists smart meters tested with the Homey Energy Dongle.
Meter Model | Compatible | Countries | Notes |
Aidon 7410P | ✅ | 🇫🇮 | |
Aidon 6483SE | ❌ | 🇸🇪 🇩🇰 | Uses HAN, not P1. |
Iskra MT382 | ✅ | 🇳🇱 | |
Iskra ME382 | ✅ | 🇳🇱 | |
Iskra AM550 | ✅ | 🇳🇱 🇦🇹 | |
Kaifa MA105 | ✅ | 🇳🇱 | |
Kaifa MA105A | ✅ | 🇳🇱 | |
Kaifa MA105C | ✅ | 🇳🇱 | |
Kaifa MA105H2CNL | ✅ | 🇳🇱 | |
Kaifa MA304 | ✅ | 🇳🇱 🇸🇪 | |
Kaifa MA304C | ✅ | 🇳🇱 | |
Kaifa MA304H4CNL | ✅ | 🇳🇱 | |
Kaifa MA304H4D |
❌ | 🇸🇪 | Uses M-Bus, not P1. |
Kaifa MA304H4E | ✅ | 🇸🇪 | |
Kaifa MA309M |
Kamstrup 162JxC | ✅ | 🇳🇱 | |
Kamstrup 382JxC | ✅ | 🇳🇱 | |
Kamstrup Omnia e-meter three-phase | ✅ | 🇸🇪 🇩🇰 | |
Kamstrup HAN-P1 module | ⚠️ | 🇸🇪 🇩🇰 | Details here. |
Kamstrup HAN-NVE module | ❌ | 🇸🇪 🇩🇰 | Uses HAN, not P1. |
Landis+Gyr E350 | ⚠️ | 🇳🇱 | Details here. |
Landis+Gyr E360 | ✅ | 🇳🇱 🇸🇪 🇩🇰 🇧🇪 | |
Landis+Gyr E360-1P | ❌ | 🇧🇪 | Uses HAN, not P1. |
Landis+Gyr E450 | ❌ | 🇨🇭 | Uses M-Bus, not P1. |
NES 83335 | ✅ | 🇩🇰 | |
Sagemcom XS210 | ✅ | 🇳🇱 | |
Sagemcom S211 | ✅ | 🇧🇪 | P1 port may require activation. |
Sagemcom XS212 | ✅ | 🇳🇱 🇧🇪 | P1 port may require activation. |
Sanxing SX631 | ✅ | 🇭🇺 | |
Sagemcom T210-D-r | ✅ | 🇦🇹 | |
Sagemcom T210-D | ⚠️ | 🇳🇱 🇦🇹 | Works in NL, not in AT (uses M-Bus). |
Sagemcom T211 | ✅ | 🇳🇱 🇧🇪 🇸🇪 🇱🇹 | P1 port may require activation. |
Sagemcom XT211 | ✅ | 🇧🇪 🇨🇭 | P1 port may require activation. |
ZIV ESMR5 | ✅ | 🇳🇱 |
We’re dedicated to supporting all P1 smart meters with an RJ12 connector, so you can confidently order the Homey Energy Dongle knowing it’s compatible with your meter.
If your meter isn’t listed, you can still order with peace of mind. In the unlikely event it isn’t compatible, we’ll work to add support within two weeks or else provide you with a full refund.
P1 port activation
Some smart meters in Belgium, Denmark, Sweden, and Switzerland have a P1 port that your energy provider needs to activate remotely. Without activation, your Homey Energy Dongle won’t receive any data. You can usually request this through your provider’s portal or by email.
Encryption
Some energy providers in Austria, Luxembourg, and Sweden encrypt your smart meter data. Homey needs a decryption key to access this data during the Homey Energy Dongle’s setup. You can request this key from your energy provider. The process varies, but usually involves emailing them your address and smart meter serial number.
RJ45 HAN port
The Homey Energy Dongle works with smart meters that have a P1 port that uses an RJ12 connector. It won’t be compatible if your meter features a HAN port with an RJ45 connector.
Landis+Gyr E350
Some Landis+Gyr E350 models transmit a weaker signal, which prevents the Homey Energy Dongle from reading the data correctly. If that’s the case, an Active P1 Splitter is required.
Some Kamstrup meters without built-in P1 capabilities use a separate HAN-P1 module. This module comes in three variants: one is fully compatible with the Homey Energy Dongle, one is partly compatible, and one isn’t.
These modules aren’t sold directly to consumers. You’ll have to contact your grid operator or energy provider if you need one. They can inform you which version you have and whether a compatible module is available.
This module has two versions: one self-powered (fully compatible with the Homey Energy Dongle) and one that requires an Active P1 Splitter. The module’s documentation will tell you which splitter is needed.
This variant doesn’t use the P1 standard, so it’s incompatible with the Homey Energy Dongle.
