Set up Homey Pro mini with a new or existing Homey account. You connect Homey Pro mini to your router and plug it in, then finish setup in the Homey app on your phone.
Before you start, turn on Bluetooth on your phone and allow the Homey app to find Homey Pro mini. On iOS, this permission is called Bluetooth. On Android, it’s called Nearby devices.
1. Connect and power up
Plug one end of the Ethernet cable into the Ethernet port of Homey Pro mini and the other end into your router.
Connect the USB-C cable to the power adapter and to Homey Pro mini. Then plug the power adapter into an electrical outlet.
2. Wait for the blue LED
When Homey Pro mini starts up, its LED on the front blinks white. After a minute or two, it starts to breathe blue. Homey Pro mini is now ready to be set up.
If the LED doesn’t breathe blue after two minutes, reset Homey Pro mini and try again.
3. Finish setup in the Homey app
If you’re new to Homey
- Download the Homey app for iOS or Android at get.homey.app.
- Open the app, tap Create Account, and follow the instructions to create your Homey account.
- Tap Set Up Homey and follow the instructions in the app.
If you already use Homey
In the Homey app, go to the Home tab and tap your avatar. Then tap My Homeys → Add New Homey → Homey Pro mini and follow the instructions in the app.
