System Requirements
Homey Self-Hosted Server runs on a variety of hardware, with a minimum set of requirements.
- An Intel/AMD or Arm 64-bit CPU.
- At least 1 GB available RAM.
- At least 1 GB available storage.
- A dedicated LAN IP address.
When running inside a VM, choose Bridged Networking to give the VM a dedicated IP address on your LAN.
Installing Homey Self-Hosted Server
1. Open a Terminal
Open a Terminal or connect with SSH to your Linux machine.
2. Install Docker
Install Docker, if it isn't installed already.
$ curl -sSL https://get.docker.com | sh
$ sudo usermod -aG docker $(whoami)
$ exit3. Install Homey Self-Hosted Server.
Install and start Homey Self-Hosted Server. It will automatically start upon reboot, until you stop it.
$ docker run \
--name homey-shs \
--network host \
--privileged \
--detach \
--restart unless-stopped \
--volume ~/.homey-shs/:/homey/user/ \
ghcr.io/athombv/homey-shsIf you prefer Docker Compose, learn more »
4. Continue on iPhone & Android
Open the Homey app for iOS or Android to add a new Homey, and select Self-Hosted Server.
Updating Homey Self-Hosted Server
1. Open a Terminal
2. Pull the latest Image
In the terminal, execute the following command to download the latest version.
$ docker pull ghcr.io/athombv/homey-shs3. Remove the old Container
Stop and remove the old container by executing:
$ docker stop homey-shs
$ docker rm homey-shsYour data is safe, because it's stored in the
~/.homey-shsfolder, which lives outside the container you just removed.
4. Start the new Container
Finally, start a new container by executing:
$ docker run \
--name homey-shs \
--network host \
--privileged \
--detach \
ghcr.io/athombv/homey-shsCreating a Backup
To create a backup, copy the files & folders in ~/.homey-shs to a safe location.
To restore a backup, put them back before starting Homey Self-Hosted Server.
Help & Troubleshooting
If you're stuck and need help, head over to the Homey Community Forum.
